Hello all im in search of a traffic arrow preferably whelen or the arrow head ends off the frame for a 500 series front load like the TANF85 and tam85 if you know of one im located in canada...
Its still pretty busy, but yeah last year was thinner then normal. I've mentioned this in the past but Early buyers, and people going as vendors and getting all the cherries have made this much...
If you use an external flasher like the ULF44, you will use only two wires for each lighthead: power and ground. Each lighthead will need its own power wire run back to the ULF44. Ground wires...
Are the CB fuses those two silver rectangular boxes, located near the lower right corner of the PS board picture? (but look more like circuit breakers)?
Thanks John
Here's the front and rear views of the P/S. The 12V Cig plug fuse meters out Ok.
I'll re-verify 12V Cig Plug polarity, as someone has replaced the OEM plug.
I tried applying power to the P/S...
Edit. You can use the sync tab for phase 1 with other heads but to add additional LEDs I would piggy back each of the main 4 outputs rather . I run 6 heads in total without an issue with all 4...
The sync tab is to connect to another flasher so that the two talk to each other and you get the same flash patterns but for only certain of the flash patter. The output of the flasher is done on...
I haven't ordered any from him since '24 but I don't think they fall under the current duties. I still had a few sets in varying sizes that I needed for my projects but I do need to order more. I...
ELO, a quick question about shipping to the US. Were there any additional customs or duties fees on top of the eBay prices to get those magnets shipped to the lower 48?
You're welcome! And welcome to the site! Yeah, I pretty much swap out all of the old ceramic magnets on any of my throw lights and mini bars with these neodymium ones. I've used the 2.6" ones with...
Bottom line up front, it might be better to use a solid-state headlight flasher designed for your specific vehicle instead of a stand-alone LED flasher.
Our shop found out the hard way how Dodge...
ELO, thank you for sharing the source of those rare earth magnets arranged in discs. If they can hold up against West Texas gusts, it should be solid anywhere.
Yikes. I will fire up my DM2 this weekend. For those in service who used them frequently on patrol did you ever find there was a time limit when they started to get too hot and stopped working. Or...
Theses are from a time period when strobe supplies became less servicable. As RS485 stated, many of the components are in the potted hybrid board which isn't servicable. Full on DOA is usually a...
