I forgot to link the source of the magnets. He's out of Canada and I get all of my magnets for mag mount projects from him. I also forgot to mention I converted a 24" FS Legend into mag mount with...
Hello, Jennifer! Here's mine. This is a bit barbaric as it was a quick and dirty build I needed for a project I was on, but it works. These magnets are 3" diameter all stainless discs with...
Flyride on YouTube but I would not be flashing driving headlights even with relays. Don't actually know if it can be done as all the LED wig wags I see about would be factory option or a dedicated...
This doggone Vista I'm working on has a problem for every solution. Does anyone know a source for the 90 degree (right angle) turn quick connects Vista's secondary lamps use? They must be the...
I restored this lightbar in the same configuration I got it. Like most purchases, the seller didn’t know much history about it. He believed it had been a law enforcement bar prior to switching...
@tsquale is right, I am not familiar with the Fed Stratos line.. was this a European thing?
The rotators in the picture if you squint enough are whelen.
Nice StreetHawk!
I guess these bar may had Dynaray Intersection lights and they were replaced with these stationary Jetsonic reflectors at some time.
The outer rotors are mounted further back...
Band: 403-470MHz
Model: AAH55QDH9LA1AN
1000 Channels
Firmware: R01.12.17
4 watt
Wide and Narrowband
Radio is in excellent condition with a new housing. Last programmed with CPS 2.0 and has been...
been abit, figured I would take a quickie of where its sitting now
Its mostly reassembled, some wiring block hookups and then remount the rotators.
I did a good run on the motor with how it...
Hi everyone! I have a 2015 Dodge Journey
as my POV. It has a positive switched headlight system. I am replacing the bright light bulbs with LED bulbs. I am wondering if I use an LED flasher (...
