Whelen Light Bars
Firstresponder25
May 8, 2026
6
NH
I picked up a couple of older Whelen Edge and LED Liberty bars the other day. Tried hooking them up to a converter and would not work. Tried hooking them up to a car battery and battery charger with still no luck. Looking for suggestions.
Most Whelen lights require constant power to primary red wire + and the ground typically black. The other wires in the bundle are typically trigger wires for specific functions. Best advice is to try and pull a model number and lookup a wiring schematic, so you do not accidentally blow something up .
Reactions: Abacus
Upvote 0
Tried the wiring schematic and still cannot get these bars to work. So, I am hooking the red to power and black to ground and get nothing, any ideas what I am doing wrong?
Upvote 0
So as I said previously the Red/Black wires will energize the bar when connected to a power supply. Functions are triggered by applying voltage to the smaller bundle of wires individually to perform other functions. I think I have a YT video on a liberty bar I was working on.. try this..
Upvote 0
I have tried just that, Red/Black wire, then the smaller ones with no luck. Unfortunately, your video does not show how or which wires you hooked up.
I would use the video as a reference, I do talk about wiring colors and what they did during the video. However, with that in mind.. your light may not be wired the exact same way. Which is why I said find a wiring diagram for your specific model. For the rest, I will leave to the Whelen folks here.
I hope you get it working..
Reactions: Firstresponder25
Upvote 0
Also, check the fuses. There are fuses for the Power Supply's, the relay matrix board options and for the board itself.
Have you opened up the bar??? be carful with the power supplys. They have ugly voltages running around inside. Wait 10 min. before messing around with them after powering it up.
Reactions: Abacus
Upvote 0
Jumpoutspooky
