Whelen Whelen Liberty II, duo color in solo bar?
gawadsten
Feb 10, 2025
11
Norway
Hello, I’m lokking at a slightly used (2024) Whelen Liberty II with WeCanX. The bar is originally a solo amber bar. Does the harness and board support duo in the rear as standard? I want to upgrade some of the modules to have duo color.
I/O boards are the same. In WCX, they are even the same board between the majority of the models. Wiring harness should be the same, as all the modules also share the same plug. One thing to know though, is that you will have to swap out all modules to the same type. You cant run half solo, and half duo.
Upvote 0
thank you. Do you perhaps know if the modules in older wecan fit in wecanx model?
I also think it has TA on separate cables, if that has any to say regarding duo/solo.
Upvote 0
quarterflash
