Whelen Whelen 500 Linear LEDs won’t sync
crownvicNL
Aug 4, 2024
35
Netherlands
I have 2 Mirror Beams and 2 Whelen 500’s installed in my grille. Recently replaced one of the mirror beams as it stopped working, and now suddenly my entire setup is out of sync. I had a simple pattern setup - right side (blue) would alternate with the left side (red).
Tried almost everything. Turned everything back to factory settings and scrolled through patterns, yet nothing will sync - even though the gray synchronization wires are connected together.
I might have accidentally tapped on the ScanLock wire whilst replacing my right Mirror Beam. How would I go about fixing this? It looks like a proper mess right now.
Maybe one side is in phase with the other?
What controller are you using?
Reactions: tsquale
Upvote 0
sanders5135
