What’s wrong with my Arges?!
NoLimitSquads
Feb 11, 2021
354
This unit has been in service for 3 weeks. Arges is horribly shaking like the motor is freaking out… any idea how to fix?
These things do weird things all of the time. If you are hooked up to a Core, make sure that firmware is up to date. But what Ive had the best luck with, is re-calibrating it, then cut all power from it, and then re-connect. Not sure why, maybe they get jarred out of calibration while driving or what, but that is usually the issue.
Reactions: LED
NoLimitSquads
Feb 11, 2021
354
No core but I’ll try disconnecting for a bit see if that helps!!
Make sure that you re-calibrate it. If no core, the power disconnect probably wont help. Think of it like this(with Core). Every time that you update your computer, it needs to restart. Core is similar, after it updates, a restart(power cycle) will help it re-boot properly.
Reactions: LED
FFruh
