Feniex Apollo!
FEVER said:
Dummy (steady burn) modules are usually recommended for using with external flashers.
Do you mean not using an F6 and one of those horrible cheap LEDs? Or is there an F6 that has a steady burn and when the dealer asked me how I was using it (and said hooking up to an external flasher) they sent me the wrong type?
I have set them to single (slow) flash and it seems to work quite well when using the quad and quint flashes on my external flasher... However on the slower patterns it can look weird.
And just for context, I wanted to sync my dash light (Apollo 2X) with the external flasher. So I asked the dealer to send me 2 F6s and a dash shroud. (The dealer said, just purchase the Apollo 2X and put in a note to have the F6 separate. What was shipped to me were two separate interior F6, 2 pig tails and a dash shroud.
Pfire472 said:
Are the exterior F6s available yet??
Yes. Some are back orders but fir the most part they are available
Red and white are now in back order until the second week of May
Is there a "dummy head" version available that can be red/blue? I want to sync all red on my vehicle then all blue using an external flasher...no internal flasher would be needed...thanks
Yes there is. But you will essentially have to run four wires per lighthead. The light head needs to have power (and ground) at all times, then you will need to run a positive switched wire to each of the modes from the flasher to act as the signal activation for the mode you want on.
Frustrating to find this out now... Do these run about the same as the "normal" F6?
thekameleon said:
I don't want the brake pop, I just want steady so I can use my external flasher. I know about the two modes.
Toying with buying one of these for an aux brake light on my motorcycle.
So wait, the Brake Flicker pattern is back? I know Feniex removed it for awhile because I specifically purchased a set of Cannons (Y-2013) for it and they didn't have it.
Yes it is back on all three mode (new) cannons, new apollo F6 module products and the new T-6
Nothing has been mentioned.   I have my speculations based upon the time I have spent focusing on Feniex's product line over the last two years but... I'm not in the business of spreading rumors. I will wait until they release an official announcement.
As always, I believe it will be competitive.
Reactions: unlisted
someone needs to drop a line they need to make multiple warning modes in addition to arrowsticks (like tomar did) ;)
They also need to add some more "basic" flash patterns- ones which do not utilize all the lightheads.
Feniex 4200 has a 3 position (4 if you include off) progressive slide switch.. just sayin.
Reactions: tsquale
They need to hurry up so I can see it, want it, and not be able to buy it
Arrow patterns?
Same arrow patterns as the cobra. I'll see if my brother can bring his car by so I can get some videos of the Apollo stick in it and do the arrow patterns.
For those of you who have the feniex apollo f6 exterior modules, what kind of steady burn is used?
Does it come on steady at near full brightness and remain near full brightness?
Or does it come on steady at near full brightness and then gradually dim?
I am trying to determine the suitability of using these lights as auxiliary reverse lighting.
They steady burn at the same power they flash at. Any dimming is slowly caused inadvertently via heat.
1)any update yet on release?
2) how are the Apollo series behind factory tint?
apollo sticks have been pushed back to the second quarter of 2015. (This is why I caution people about anticipating release dates) the Apollo doesn't do well at all behind tint. Go with the cobra series.
I personally don't think apollo modules should be mounted anywhere but outside of a vehicle.
Thank You for the info. That's a bummer, I wanted multi color lights for the rear. Now about the 600 interior model you have contact for price :)   ill pm you Fever.
Anyone know if I would be able to control the colors separately. I'll explain what I need. I'm a volunteer FF and my primary color would be blue. I'm also the regional Dive Team Chief so I also run red. I would like to add amber as well.
My idea was a 4 head stick with two red/blue heads and two blue/amber heads. I would like the ability to control each color individually. Thanks for any help.
Does anyone have a flash pattern demo of the passenger side only Apollo interior bar or is it the same as the full bar, just that half? Thank you
ok so if I watch any flash pattern video from members just look at the one side, patterns aren't different for a full versus a half.
Reactions: Tom@Feniex
The Apollo stick is useless behind any glass, so it has to be exterior mounted. You cant even mount it in the front, with all of the V shaped mirrors, it catches all sorts of bugs and debris. Why isnt there a lens that covers all of that?
Reactions: Station 3
I'm not sure I'd agree apollos are useless behind glass.  By mirrors do you mean the angled sides of the lightheads?
Well they're certainly useless behind tinted glass. Im talking about the litle angled reflectors in between the lightheads.
I can't speak on their effectiveness behind tinted glass because I don't mount lights behind tint, nor have I seen any of these behind any significant tint.    How are the slants a problem to wash? Just too narrow of a space to clean?  I wonder if it would be feasible to make a cover?
ParaLite
