Band: 136-174MHz
Model: TK-5220-K
512 Channels
5 Watt
Narrow & Wide band FM
Analog and P25 digital
Radio is in excellent condition with minor signs of use and programs with KPG-112D. Package will...
I have a pair of B/W DUO Ions, along with mounting kits. These are warranty replacements, so not in the standard package. They have a connector on the end that can be removed and the lights wired...
Hi All,
I've recently bought a green Edwards Signaling beacon. It's a nice-looking light but a bit too noisy for my taste. It's driven by a brushed motor with a gearbox that spins the reflector...
Just wanted to share that two Soundoff Ghosts fit perfectly in a Star ULB9 shroud. The bolt pattern for the back of the ghost is dead on for the shroud. I ran this for a while, 4x ghosts in 2x...
Are you sure you linked the correct brochure? I see a DashMiser brochure, but I don't see any about California models.
I see the one sentence comparing the DashMiser to the DashMaster...
Here you go John,
I found a copy of the OEM Whelen brochure for the Dash Misers = DPM2S and DPM1S;
http://www.fleetsafetysupply.com/whelendashmiser.pdf
Hi Dan,
Do you still have the single Dash Master that you previously posted?
I'm also looking for a FS Fireball with the Motorcycle mounting pole.
Thanks
I recently got this beauty out of northern Idaho. The owner had no history on it’s past. They got it in an auction. It came with the red beacon dome but I was able to get my hands on a blue one...
