Band: 403-512MHz
Model: AAH56RDC9WA1AN
32 Channels
Firmware: R02.24.2.12
Bluetooth
Digital/Analog
Capacity Plus Trunking
AES
Radio is in good condition with minor signs of use and engraving on...
I'm looking for a tri-color (R/A/W) or dual color (R/W) stick for the rear of my '20 Ford Edge that can do TA/Warning functions as well as flood with the white function. Thanks!
I think one manufacturer swapped a couple of wire terminal positions on their power supplies, but I don't immediately recall the details. Now that you bring it up, I have never considered whether...
Looking for 6 Blue Con3 heads and 2 corners to put into a Justice bar. Or if you have a whole bar with at least those parts and are close to central Pennsylvania I would consider that too.
Thanks
Band: 403-512MHz
Model: AAH56RDN9KA1AN
1000 Channels
Firmware: R02.10.10.0001
Bluetooth
Digital/Analog
Radio is good condition with minor signs of use but nothing that...
Band: 403-512MHz
1000 Channels
Bluetooth
Digital/Analog
I’m aware they work the same, I just trying to ensure red = red, black = black, and white = white across manufacturers so I don’t burn out a flash tube.
I think for awhile Federal swapped out the black and white, but it was only in the amp connectors. Most strobe heads work the same. The only exception that I know of is the Federal signal "J"...
Honestly, the b-link system was a good system… you’ve got some leds in the 500 series in the grill and at least one pair of 400 series 6 over 6 leds in the bar… I think I’d clean up the lenses and...
I have a Target Tech branded halogen Highlighter that someone cut a bunch of the wiring for, internally. Still not sure why. Does anyone have a wiring diagram for this, or know where to reconnect...
Did all strobe manufacturers wire the strobe bulbs the same way? In other words - are all manufacturers red, white, and black wire on strobe bulbs the same function? Can I match wires from...
ISO the following Liberty II parts:
RED lens section for 1 side of bar
2 RED corner modules
5 RED inboard linear 6 modules
1 RED lin 3 module (that goes next to takedowns)
Have blue to trade...
The 174 and 176 use the same bulb holder (I like Dan's term "cage"). The 175 cage has two bulbs with one angled up and the opposite side angled down (NYPD had a special cage where the up-angle...
I have (4) Whelen Howler Amplifier's (WECANX) for sale date of manufacture 02/20. These were only used for demo purposes so very little usage. They are in excellent condition, with all the...
