Hey, lol.
I dunno been going back and forth about this car, since discovering its bad points. I understand all these cars suffer from Ford's crappy design, heat boiling the PTU and internal...
You could use a Whelen SSFPOS flasher. I’ve installed them on other non police package vehicles with factory LED headlamps. No issue at all. Should be the same with the Tahoe. The Lighting Control...
I had a Tech Sergeant that had been stationed there; he told I story I can't repeat. He did GLCM, too.
Your picture reminded me of this, too, cropped to redact faces.
Its a Whelen 5000PA. If you can even find one expect to pay a lot. Most guys who have one wont part with theirs. They are extremely rare. I bought one back in 2015 and it cost me $1000.
Wow you know that's a damn good question I don't have an answer for that myself anybody out there have an answer?? That's the reason why I like the old style ones with halogen lights so you can...
But where is that Alert Fire Team building located?
Ground to sheet metal seems like a bad idea in itself. Get both the Positive and Ground hooked to the battery with a proper fuse as close to...
It's always been a bit finnicky, I don't believe the previous owner had it on there for long before selling the truck to me. It's the only Twinsonic I've ever seen in person, so I can't tell if it...
I worked as an outfitter when the 12 was introduced. The minimum gauge wire we used was 12 and did just fine. I am not familiar with the military system described by @local_sheriff but he makes a...
Looking for shroud/mounting brackets for older version inner edge with the halogen inner lights. Need to convert from explorer to F250/Super Duty, preferably 2005/2007 since its going into my '05...
Got to love the B links got the mpc01 the siren and a relay unit for as well I just don't have the bar I have a LED bar that's not mounted on my vehicle yet... But I can't afford these things...
Somewhere I might have a download of that PDF about that bar depending on what that bar is I went there before they killed the old website and create a new one which eliminated a lot of the old...
Did you search Whelen's website for that particular model it should bring up the whole entire wiring harness or you can make a request to the technicians like I used to do I haven't talked to any...
This is the picture of the Whelen Commander Model 5000 strobe beacon with the speaker build right underneath the dome. It is the one I am looking for. If anyone has one and/or knows of someone...
Got this in the shop yesterday. Looking for a red dome for it. Scratches or needing buffed up is fine. Not looking for perfect, just usable. No cracks. Crazing ok. As long as it fits the base...
Yes, the chains are intended to drag some. They were liberally lubricated by FedSig in white lithium grease that may be quite thick by now.
Your bar is, as we say, is quite a bit crusty (not...
