I'm trying to figure out how to use the WeCan software to program lightbars. So far I've got the gist of it, but I still have some questions/issues.
1: To alternate lights you select the light heads, choose a pattern, and click alternate which alternates flashes from the left side to the right side. But what if I want something like this.
[off][on][on][off] to alternate to [on][off][off][on]? [These are the four inboard modules on the front if a Liberty lightbar.] [ SOLVED - This is done by selecting every other lighthead and choosing a custom phase.]
2: When programming the WeCan for a single color liberty with takedowns and alley lights, I cannot seem to program the rear traffic advisor, but if I choose a model that has a "split traffic advisor" then I can program it. Problem is the ones with the split traffic advisors do not have the option of alley lights and takedown lights. How is this solved? [Figured this out. You have to set your TA in the WeCad program].
Also if anyone has some configuration files they could send me that I can look at I'd appreciate it. Just PM me if you do.
EDIT: Since I solved both issues I am simply leaving this post up in the event that someone else has similar issues and stumbles accross this.
