First things first: get yourself the proper wire guide. Use Zapp's link above to the wire guide, ensure you're using proper power wires. Ensure you have a good solid ground.
They work now? Enjoy your bar!
Still no go? Down and dirty time - trace your wires into the bar. Are they intact ( no cuts/tears /holes) ?
Remove the four/eight screws to your endcaps, carefully pry away the black gaskets so to not damage it/them. Slide the corner strobes out, remove all lenses/dividers. Remove the four bolts holding top rail/frame in place ( carefully and mind the washer/seal ) Remove top frame/rail. Now to check your interior wires. Scope your board and supplies first. Does your bar have one or two power supplies? If two, try swapping wires and give that a go. (ensure wires are for strobe supply and not to led/halogen heads)
Best case: improper wire or bad wire
Worst Case: Bad power supply
If its the supply, ensure you replace with equal/same supply. Too little current and the strobes may not trigger, too much and you may blow the tubes.
Hope this helps and best of luck!
PS: While the bars apart, nows a good time to check the gaskets on both endcaps, the four retaining bolts to top frame/rail, and each divider ( one divider has two (2) gaskets. Also double check all other interior wiring for frays/splices/cuts/burns etc [halogen/strobe wires especially] )
