Yet another random Whelen related question from me:
So I figured out the esiest way to make a TA is with a 12 pin connector, so a controller with a 12 pin port would be needed. I figured maybe an ol' Cencom Gold would work as they've got 12 pin TA ports. However, before I eventually buy anything, does the Cencom Gold have any internal flasher that could flash 4 pairs of (BAsic 2 wire power/ground) 500 series heads (8 total 500 Series heads) and 4 vertexes? Being able to control the TA and the 8 500 Series perimeter light through one control system beats buying a used TA controller, A ULF8, and something to control the ULF8 with (Some switchbox). I was looking at the Whelen Cencom Gold PDF (Refer to Pg. 5&9) and listed the following outlets: (1) 40 amp, (2) 20 amp, (5) 10 amp and (4) 0.25 amp. On the diagram on Pg. 9 it shows the location of the 40 and 20 amp outputs, but it doesn't identify the 10 and .25 amp outputs. So yeah if anyone know if the Cencom Gold has internal flashers capable of flashing 8 500 Series heads and 4 vertexes, do let me know!
