Would you be able to do a video of the lighting set up with Carbide when you have the install complete? Does your dept like to run cruise lights or use steady flash or steady burn for it's fleet? I'm getting my department set up using cruise lights and having a separate button programmed for steady flash on the lightbar etc. If it's a hit I'd like to educate them on the carbide and it's ability to do all that for our slick tops.
Yes, you can setup a cruise button. You can program only a few select outputs and lightheads on your lightbar, or you can have every lighthead programmed into your cruise button (sort of like what a lot of CT LE agencies are doing with CanTrol).
Steady Flash is being used by my agency, the MA State Police, CT State Police, RI State Police, and several smaller departments as a reduced power night time park pattern. Carbide will do this and sync your lightheads with your WeCan bar(s). The pattern is a favorite of ours and is a big reason we probably won't be going with the Soundoff bluePRINT.
I love the Carbide so far. There are a few bugs with the software, but it's only version 1.00.00 and Whelen is already hard at work fixing them.
Looks awesome. Nice setup too. I can't wait to get mine. What brand of console does the vehicle have? Also, was the carbide able to do everything you wanted? Thanks.Here she is. Whelen Carbide installed. Just waiting on the radios and graphics before she's on the road.
TACKLEBERRY - any chances of seeing some photographs of the parks unit after graphics are on it?
The pricing I have seen so far has it running about 1200.00 So that's about 300.00 or so more then the Sapphire.
You mean the WeCan External Amplifier?You require the wecan amplified splitter
Is it possible for someone that has experience or knowledge of wiring the carbine to explain how to wire in an Inner Edge and a Rear Inner Edge RTX into the system. I just get hung up on the fact that there is only one WeCan Input and I have 2 devices for that. Maybe I'm just overtired and missing something. But anything (pictures, explanations, loud noises) would help.
