Wanted: Modern Whelen 3degree
I have the 3 degree part, but it looks very different from the 2 degree part that you posted. Do you need the 2, or the 3? I don’t think that I have any of the 2 degree parts.
Thank you. Your absolutely correct about the parts looking different. That is the information that Whelen provided me including the exact same part number. I have an email into her and I will get back to you but now looking at it she provided me with the wrong part and part number so I guess we are after the 2°.
I think that the 3 degree part is for standard feet, and the 2 degree part is for the low-profile feet. Thats just guessing off of looking at the pictures. Ill look around a bit better later today and see if I have any of the 2 degree anywhere that isn’t in the normal inventory location.
Your correct. We have the 3° on our standard mounting feet. On our low profile fee, we have the 2°. I think there was just confusion on Whelen’s end an understanding which feet we were using. I put an email in and I’m waiting for a response because I know they told me that the 3° are discontinued.
If you are using a Lib, Legacy, or other bar that uses that mounting system, they also make adjustable mount kits. That might be a better option to make sure that you get it perfectly level.
I think these are the 2 degree parts you are looking for. So far I found one used bar that has a set of these on each side. They were spun around and stacked on each other just making it a small level spacer. Let me know if you aren’t able to find new.
shawn1
