Parts to switch a WeCan FST or RST into a WeCanX FST or RST. You will reuse (1) of the existing harnesses in the bars. Dip switch settings apply to the dip switches on the I/O boards so that the system knows if it is an FST or RST. This info can be gleamed from the following two WCX install guides:
FST:
https://www.whelen.com/install/14C/14C75.pdf
RST:
https://www.whelen.com/install/14C/14C73.pdf
FST Solo/Duo (Dip Switch: 1= ON, 2= OFF)
(1) - 02-016J531-00 - PCB CONTROL BD 24 OUTPUT INNER EDGE WeCanX SMT
(1) - 46-0788625-01 - HARNESS "D" WeCanX INNER EDGE FST/RST
(1) - 46-0788625-00 - HARNESS "A"/"B" WeCanX INNER EDGE FST
FST Trio (Dip Switch: 1= ON, 2= OFF)
(1) - 02-016J197-00 - PCB CONTROL BD 36 OUTPUT INNER EDGE WeCanX SMT
RST Solo/Duo (Dip Switch: 1= OFF, 2= ON)
(1) - 46-0788625-02 - HARNESS "A" WeCanX INNER EDGE RST
(1) - 46-0788625-03 - HARNESS "B" WeCanX INNER EDGE RST
RST Trio (Dip Switch: 1= OFF, 2= ON)
Source:
https://www.facebook.com/groups/841...N_qU2SteAM-ZoMoIzHUv0DmxMkchoX7nM&__tn__=R]-R
