Please bear with me so I can explain everything. I have a 2015 Dodge Charger Pursuit.
Had a touchmaster Delta installed.
I grabbed the two horn wires from behind the glove compartment. Both wires were connected to the back of the touchmaster Delta. One went to the screw marked horn in the other one went to the screw marked ring. When the touchmaster Delta slide switch was to the very left, My factory horn would work. If I put the slide so I can switch in position 3 I would get the siren.
The Dodge Charger also has factory wig wags and flashing tail lights. I had one wire to the back of the touch Master Delta going to a switch and I had the rear flashers going to another switch everything worked.
Today I decided to install my new siren.
Generally speaking the siren works. But I am having a problem with programming and the wires from my factory horn.
I thought I was following the installation instruction from the page and when I made the final connection it made the siren sound without doing anything on the controller
So obviously I hooked up and correctly.
Also I tried hooking up the front wig wags to a wire that was triggered by I believe button nine but it wouldn't flash the lights again I don't know if I have a wiring issue or a programming issue.
Any help would be greatly appreciated.
Gary
Gary
