O officermatty Junior Member Member Aug 19, 2010 43 0 45 Greensboro, NC Aug 25, 2010 #1 Anyone know if you can modify the Federal Signal Touchmaster Delta to run the ultra hi-lo only? Unitrol says no.
Quentin Senior Member Member May 21, 2010 956 23 34 Lancaster, Nebraska Aug 25, 2010 #2 nope but you can on the UTM
Pimp Veteran Member Member May 16, 2010 1,872 204 Louisiana Aug 25, 2010 #3 You can with a Unitrol Omega 90 amp.
F FDNY 10-75 Member Member May 24, 2010 457 6 NY Aug 27, 2010 #4 Apparently Sean (?) from EVModules can modify it to do so... Or so I was told. Anyone else hear this?
Pimp Veteran Member Member May 16, 2010 1,872 204 Louisiana Aug 27, 2010 #5 I don't know if he can do that model specifically... but if it can be done... he is the man.
