Have the two sirens installed in my truck and neither are fully functional. I think they're simple fixes, but I just can't figure it out.
I can't get the sweep mode working on the TD. I have a separate switch wired for the horn ring and it isn't tripping the sweep function. I've tried to match the diagram the best I can, but it isn't working correctly. Does it need power or ground or something to function correctly? Or does it just jump between the two connection points on the back of the unit?
And I can get the 12Q to work on manual mode, but not with the wind down. I am fairly certain that the pins aren't the correct ones and they aren't long enough. As I was wire testing the connections, I made contact with the pin end and shifted it, turning on the siren. Does anyone know where I can find replacement pins for the connector?
And last question. I want to wire in the siren brake for the 12Q, but didn't see it in the manual. Which connection is that?
