Title/Name of item - Strobes n more EFLOOD 7560 WARNING
Manufacturer - Strobesnmore USA
Link to product from MFR. - http://www.strobesnmore.com/Strobes-N-More-EFlood-7560-Lumen-Flood-Light.html
Why I got it - For a boat project/playtoy that will be used mostly at night with the secondary application for water rescue. I have purchased 2 SNM EFLOOD 4200 warning lights previously and have had good experience so far with the brand.
Price paid - $119.99 plus free shipping for being an elb member.
Description - (From the MFR) The Strobes N More EFLOOD7560 is an incredibly bright 7560 lumen flood light in a di-cast aluminum housing built to withstand the toughest environments. A heavy-duty job required a tough light and with an all aluminum housing di-cast housing, stainless steel mounting hardware, and PMMA durable lens these lights were built to last. The 3-watt Cree LEDs are built on a vibration resistant LED board so they will take a beating and not let you down. At less than 7 inches wide and less than 4 inches deep these lights pack quite a punch in a small housing. The adjustable stainless steel mounting bracket allows full up/down and side/side mounting options. Use these lights anywhere extra light output is needed.
Features:
• Die-cast aluminum housing, good appearance, wear-resistance and anti-corrosion.
• Special heat sink design to dissipate heat rapidly, longer life span and more reliability.
• IP67 full protection grade design, the lamp can work under water and any severe environment.
• DC power supply system, this lamp can be adapted to any vehicle, ship and fieldwork environment.
• Super Bright Next Generation light source, the light effect is up to 90Lm/w and the life span is more than 30000H.
• Stainless steel material is adopted for all hard parts of this lamp, which make it sturdy, durable, hard to anticorrosive.
• Luminous Flux: 7560Lm
• Full 72 watts of output power.
• Can operate on 9-32 volts DC
• Working Temperature:-45 ~55°C
• Life Span: ≥50000Hours
• Color Temperature: 6500K
• White box: 1pcs/BOX.
• Weight: 3 Lb.
Results -
Packing/shipping - Item was purchased 4th of July weekend. Packaging was excellent. Light was in its own box with foam surrounding it which was inside a larger box packed with foam peanuts.
Ratings (1 = poor, 5 = expected, 10 = very cool)
Usefulness 8 Does what it does pretty well. Spot throws about 125ft and flood gives wide area light at about 75ft.
Innovation 5 Nothing fancy other than the spot flood combo. Nice that each function is wired separately.
Appearance 6 Size is a bit big for mounting on the front of a vehicle but would be great mounted on a pole or roof of a rescue apparatus.
Quality 9 Only plastic on the light is the lens and the inner reflectors. Stainless hardware is a nice touch, and powder coated aluminum body should last. Sealed well.
Price 6 Not bad compared to the prices from competing MFRs. Appx. .015 cents a lumen.
After tinkering with it I found that the frosted "flood" optics were snap in and could be removed turning the entire head into a gigantic spot light....see the results below. This will probably void any warranty so I wouldn't recommend it
The shed in the following pics is about 125ft away with trees behind it at 150ft. The garage wall is 40ft in length by 9ft tall.
From Factory...
Half spot
![1x spot.jpg 1x spot.jpg](https://elightbars.org/forums/data/attachments/99/99392-4ff9f2ae0aedbbf3988378739887c2a4.jpg)
![1x spot right.jpg 1x spot right.jpg](https://elightbars.org/forums/data/attachments/99/99397-13e0760f36ae2831e3783e947560b605.jpg)
Half flood
![1x flood.jpg 1x flood.jpg](https://elightbars.org/forums/data/attachments/99/99393-8bf5583db39f125c0ab8855ac325834a.jpg)
![1x flood right.jpg 1x flood right.jpg](https://elightbars.org/forums/data/attachments/99/99396-afbb40dea7847ab14a4fe2d36fba37d8.jpg)
Spot/flood together
![spot flood.jpg spot flood.jpg](https://elightbars.org/forums/data/attachments/99/99395-f037be72b775a2e866da72d9421807ca.jpg)
![spot flood right.jpg spot flood right.jpg](https://elightbars.org/forums/data/attachments/99/99399-48c91fbf256fd6d3a55d51e034dfd291.jpg)
After removing the frosted flood optic inserts resulting in 2x the spot.
![2x spot.jpg 2x spot.jpg](https://elightbars.org/forums/data/attachments/99/99394-b915ab946f7a4ce5843f1a81a5952b38.jpg)
![2x spot right.jpg 2x spot right.jpg](https://elightbars.org/forums/data/attachments/99/99398-641fb540a507a16996a502427028fbec.jpg)
Features:
• Weight: 3 Lb.
Results -
From Factory...
Half spot
Half flood
Spot/flood together
