Chris Demos a Whelen Broadcaster Digital Voice Message Recorder
http://sirennet.com/whbrdcstr.html When cell service is out or you need to supplement your Mass Notification Warning System, the Broadcaster Digital Voice Message Recorder from Whelen will be there to alert, inform and direct the public. Whelen, one of the largest Mass Notification System manufacturers brings you a new mobile digital voice recorder and playback unit that is a valuable addition to other emergency notification systems. Designed for use with any emergency vehicle's siren system, simple switching functions will allow the radio repeat function to playback a pre-recorded message from the Broadcaster. Also, this combination system will allow live voice and switchable siren tone functions. Broadcaster is a great addition to a Whelen Mass Notification System.
Features:
Wired through your current siren amplifier's radio repeat function and allows you to record and play back an emergency message.
Record your message by simply pressing the PTT button.
When the record light illuminates, start your message and when done release the PTT button.
Play personally recorded message once or continually repeat the message simply by holding the play button for 2 seconds.
Easily add a siren tone before the message for a complete repeating loop.
3 siren tones to choose from, yelp, piercer and pulsed air horn by toggling through the select function switch.
Record up to a 30 second event specific message. Re-record a new message to change.
Toggle between radio pass through mode and message broadcast mode.
Adjustable preset radio repeat volume.
Adjustable preset recorded message volume.
Easy to understand and use with front panel mounted LED display.
Small size allows for mounting almost anywhere.
Includes removable microphone.
Adjustable swivel bail bracket.
Patent pending.
Dimensions: 1-1/16" (27mm) H x 5-1/4" (133mm) W x 3-3/16" (81mm) D.
Whelen 2 Year Warranty
Features:
Patent pending.
