GranPrix Member Member May 23, 2010 530 20 FL May 25, 2010 #1 How many amps are coming from the pink ignition wire under the passenger footwell?
S shues Lifetime VIP Donor May 21, 2010 10,410 774 NW Indiana May 25, 2010 #2 If you have to ask, then use a relay.
GranPrix Member Member May 23, 2010 530 20 FL May 25, 2010 #3 I ask because I don't remember. Thanks though.
S shues Lifetime VIP Donor May 21, 2010 10,410 774 NW Indiana May 25, 2010 #4 I never knew. But seriously, use a relay. That way you can be sure not to burn your car down.
cajunblitz Member May 20, 2010 1,217 175 Saint Martin Parish LA May 25, 2010 #5 GranPrix said: How many amps are coming from the pink ignition wire under the passenger footwell? Click to expand... PINK=20 amp TAN=20 amp
S shues Lifetime VIP Donor May 21, 2010 10,410 774 NW Indiana May 25, 2010 #6 GranPrix said: So should I do: ignition to relay to distribution block to equipment? Click to expand... The ignition wire should go to terminal 85 on the relay. Ground terminal 86. Connect terminal 30 to your distribution block. Connect terminal 87 with an appropriate gauge wire to a fuse or circuit breaker at the positive terminal of the battery.
