I have a code 3 slimline, and a fed sig 100 watt speaker. The guy said the orange wires are for speaker. I hooked it up and no sound. I have a good ground, and I tried 2 power sources. Where is the best place to put the power wire?
best thing to do is run a fused wire straight in from the pos battery terminal to the siren pack or to a distribution block. make sure you have a good chasis ground (not the neg battery terminal). when you hook up power and ground to the siren pack, turn it on, you should hear the siren comming from within the pack, even with no speaker. if you dont hear that, you may have a bad pack. if you do hear the woo woo, then try it with the speaker.
pull it apart, there might be an internal fuse somewhere that is blown. if not, i would see about getting your money back if it is something u just bought.
