mx7000 unusual configuration.
2004p71
Junior Member
Aug 27, 2010
367
91
canada
I got this bar today and this is the first time I see this configuration.
It,s off course a mx7000 with 4 rotators, sweeper ,alley light, take downs and strobe!
Everything works but the strobe, and i'm missing a red one for the front.
I have a xs8000 for parts, are they compatible at all or will need some wirering ?
Heres what it looks like . I,ll post actual picture of it later.
Everything strobe in that bar looks like it was added after the bar was made new. The blue side rear is mounted in the center of that side but the red rear is mounted more inboard, and that power supply wiring looks like a nightmare. The filters look interesting too. Im thinking this bar was reconfigured at some point at the strobes were added, and the takedowns moved to the center. Clearly C3 parts were used but, I cant say from my personal knowledge if they are MX parts or if they are the same head used in the XS. I imagine the strobes all have the same type of connectors and theres probably a connector in the bar for a fourth strobe, so as long as the head from the XS is the same and mounts fine, it should be plug and play.
what are C3 parts ?
I'm really not too crazy at the configuration anyways and hate the black dome. Iwill propably end up taking the strobe out of the bar and make are more traditional set-up.
C3 = Code 3
shawn1
