I need help with the Code 3 700 flasher
boshuter
Mar 8, 2023
DBX
Hi, guys please i'm having trouble getting these wired correctly. I am trying to get two flashers on the front of the lightbar and two on the back.But, i have a code 3 mx7000. relays 'click' when power goes to them.
Lights work when I put power directly to them. I'm not sure how to test these other than to listen for the relays and the grey wires run to the lights i'm trying to flash.
Black is grounded to the light-bar and the white and orange wires went to the 6 pin connector.
I will appreciate any help.
Thanks
What source are you using to test? Bench top converters usually don't work. You will need a good 12v battery course to get the relays popping. A jump pack or small car type battery work best.
Reactions: Dave F
