How to mount dashmiser
SBFD-E-9
Senior Member
May 24, 2010
1,359
154
Washington IL
Hey all,I have a 6 head dashmiser that I want to mount in the rear window of my 01 Dodge Ram. The housing is metal and a little heavy. IT has two plastic L brackets on it. How should I go about mounting this to the headliner? Should I look for a plastic housing?
Dan
not sure how heavy it actually is. If you want holes, drill it into the headliner. For no holes, you can try 3m lock tape. Its like velcro on steroids. Its plastic loops that lock into each other. Very good stuff.
could always use small bolts with a nut and lockwasher,reinforce the headliner with some washers on both sides
minnesota_em_vehicles
