Hi All,
I have a PA300 I want to wire the horn ring to a momentary switch instead of the vehicle horn. Looking for some advise on the proper way to wire. I see there are two wires on the harness related to the horn ring. One is to go to “horn” and the other to “horn switch”. Any thoughts on which one I should use? Also I thought I read in a thread somewhere that vehicle horns are usually negative switched. Can anyone confirm if this makes sense?
Thanks for any help!
