Question for folks who have installed the 3200 unit or if other siren units use the same general wiring theme:
I'm thinking this is a combination of the wiring and the software config, of which I'm still blindly trying to figure out. instructions were followed to use the default output 9, fuse in position 2 but when I try and use the horn I get nothing.
I also thought it kind of odd that when I push the PTT side button I don't hear the speakers key up even though the config says it should be activating the PA function.
could anyone list out how things should be configured, to use the default output 9 as horn ring?
I've attached the config I'm using.
Thank you
Thank you
