Fed Sig SS-200/201 question; SS2000SM question - NEW
rwo978
5,196
196
ND, USA
Dealers, installers...
Are the control heads for the 200/201 the same? And, they are interchangeable with the 2000SS and 2000SM heads, IE, use the same amps?
Figured out the above, it works fine, but the SM doesn't flash 'warn' with an SM amp. SM otherwise finctions fine with the upper right button. The WARN would probably have to be programmed to come on with the 3 pos switch. You'd probably also have to program the horn ring to activate, I don't think that came on either. Also, when Aux A-E are programmed to come on with the 3-pos, they still come on.
**NEW**
Anyone, mainly techs, know some focus points to look at when a relay isn't working? The 3rd relay on this amp isn't working now. If I remember right, it was working when I got the amp about a month ago. I've checked the white ribbon, and it all appears seated properly. Other problem places to look at?
The control heads are the same, the amps and programming are different.
so the 200/201 heads won't work on a 2000/2000sm amp?
**NEW**
toolman60_99
