Howdy
I have a EQ2B Series B amp and two different control heads.
Curious if both of these are compatible with the EQ2B SB amp
Currently have it running off the 1st photo with the hard plastic push button and toggle switch for manual and air horn
I have a 2nd EQ2B without a control head but have a extra one with the soft rubberized buttons in the 2nd photo. Can i take a cat5 cable or what not and with the correct pinout connect it to the DB9 on the EQ2B amp and have that control head work?
Or is it not that simple and the other control head just isnt compatible? If its not then what are the pinout for the DB9 on the amp? Could enable the tones from a secondary light controller/switch to make it work?
