CTS 537 Flasher wiring diagram needed
bixfisher
Newbie
Jul 24, 2010
12
70
St. Louis
I am looking for a factory wiring diagram showing the wiring for the original Tunsol 537 flasher used in the CTS bar. I have a bar that someone altered the system and has a 552 two prong flasher. Having difficulty with the flash rate. I have two 537 flashers that I got off ebay but they flash really crazy with just the two circuits. I am thinking that the 537 has power going into X, and the rear light off Lug L and the other connection P to the front steady. Otherise the 537 flashes a crazy rate like 2 flashes a second! Any help would be MOST appreciated!
power to X is korrekt and rear-light to L also
but as the name said - the front steady burn light is not connected to a flasher ;)
Thank you Benno! That helps. I think this one I have was modified at some point before I got it over 15 years ago. There was no connector to the flasher. The flasher was a 2 pin 552 flasher. It had failed so I replaced it with another 552. The flash rate seemed OK but over time, the rate increased to the point it was getting crazy. I figured the relay was about to die so I replaced it with another 552. Doing OK but I keep reading that the STANDARD Federal used was the TunSol 537. I have one I got off EBAY several years ago but as I said above, it has a crazy rapid flash rate, almost strobe like. I have another one coming and will try it. I compare the flash rates to the CTS bar in the TV show Emergency. When I was messing around with the 537 I have now, when I connected the lamp to the P, it just burns steady. I was under the impression this was a wig-wag flasher since it is described being used for that purpose in AeryDynic bars for the outboard flashers. I guess the flash rate is directly proportonal to the voltage at the flasher.
A thermal 537 will only flash when the load is connected to the Load (L) terminal. Connecting the load to the Pilot (P) terminal results in a no-flash condition, typically used to indicate that the lamp connected to the Load (L) terminal is out.
Thank you Shues for that response. More info is better. I am thinking the one with the extremely fast flash rate is defective. I have another one I got off an ebay seller that I am going to test out this weekend and see if it has a more "regular" flash rate.
Front light is steady burn. Rear light flashes and is the only flasher. You don't need an alternating flasher, a 2 prong would work. The CTS is a California bar, which means it has a front solid steady red and a rear amber flasher.
Hi John. I appreciate the response. I know the CTS very well. I was originally interested in the original wiring diagram and why Federal used the 537. But it appears the 537 was used in several bars including AeroDynics. I had found other blogs on other web sites that described it as a alternating or "wig-wag" flasher as it clearly isn't. Perhaps Federal got a deal and purchased a ton of the Tunsol 537's over the years. I am not aware of the "P" or pilot lug ever being used. My two prong 552 works OK in it's place. I was trying to get the flash rate a bit lower because the 537's have an extremely fast rate, a little over 2 flashes per second. Again, thank you for input.
I can certainly give the 550 a shot.
My CTS bar hanging from the ceiling so both front and back are clearly visible.
I got ya. I think you are right that federal just stuck to what the had despite the unused position on it.
FedSig offered the 537 as it's economy flasher. The 537 is a "wig-wag" flasher in that it alternates. But it's a thermal flasher which results in an inconsistent, even erratic, flash rate affected by amp draw and also heat from long-term flashing periods. You're better using one leg of a FedSig FA3 or a Tridon alternating flasher.
Thank you Chiefops. I will keep this information. So out of curiosity, how did the 537 do wig-wag? I know the L terminal is the flash leg going to the AMBER in the CTS bar. The P terminal stays on steady unless I am missing something. So maybe if lights are connected to both the L and P terminals, it then performs as a wig-wag?
