Has anyone ever used these? They are a traditional nylon connector that claim to have an "Anaerobic sealant" inside them to make a secure, weatherproof connection. One of my coworkers swears by them, and prefers them over heat shrink connectors.
They claim:
- It seals itself - Just strip the wire, insert it into Bond & Seal™ and crimp. This activates the anaerobic sealant that "pots" the connector to create an environmentally sealed connection.
- Anaerobic encapsulation - Anaerobic sealant cures in the absence of oxygen. When the connection is crimped, oxygen is removed from the connector creating an ultra-strong, moisture proof connection. Sealant outside the crimp area remains in the gel form to seal around the insulation.
- No heat required - No heat guns or torches needed – and no danger of heat to connectors or surrounding materials.
- Fast Installation - Installs in a fraction of the time of heat shrink terminals. In just 2-3 hours, the connection is fully cured.
- Superior connections - Innovative new sealant prevents entry of moisture, air and contaminants while the nylon insulation provides maximum abrasion and puncture resistance.
- Superior conductivoty - With corrosion effectively sealed out, the seamless 99.9% copper connector offers optimal electrical conductivity.
