CODE3 MX7000 (6PANEL)
CCI
Newbie
May 7, 2011
8
US CA
I have several MX7000 bars, is there a way to link them together to make a 6 panel one like the one in the attached picture? I have 3 panel, and 5 currently.
it can be easy if you can either fine a frame and cut them down to the length needed, or if you are lucky, find a factory frame and go from there.
frames can be easy to find and if have the right tools and knowledge..........cut and weld works too :)
Reactions: CCI
If you really didnt want to aquire a factory bar that length you could join 2 frames via a thick flat piece of metal plate on the bottom. Using the channels for the mounting bolts you could attach the plate with mutiple bolts on each side like a gusset plate. The other option would be find an aluminum welder to join the 2.
