No, I haven't. I didn't think they still have documents for them.... Have you contacted code3 directly?
I actually thought the Model 3600 existed long before the V-Con.... hopefully they have it still, just hard to believe that it wasn't part of the PDF of the original unit.
No, I haven't been able to find any instructions yet. Do you have the manual in paper or as a file?... Did you ever find the manual you were seeking? I have one if not...
Ok, thank you for the information. I had already feared that parts were still missing.That's a 3600-L7. .... You are missing the power distribution centers. That model used two of them. One for the slide switch and one for the push buttons. Each PDC had 4 relays. The PDC for the slide switch used 3 relays for the 3 levels on the slide switch, the 4th was used for a horn ring transfer relay. ...
A few pictures of the module would be great!... I'll also take a couple of pics of a PDC for you.
Thanks!Here is the manual. I will look to see if I have anything else. ...
No problem, is still better than nothing!.... Sorry about the quality. The higher resolution file is too large.
