Code 3 sd vs twinsonic
smitty711
Senior Member
May 23, 2010
684
14
49
California
Why is the twinsonic more popular then the Code 3 Sd bars? Just seems like everyone wants the twin over the code 3 bar.
A few years back I met I guy who owned both, and he said the Twin Sonic is a better quality bar than the Code 3 SD.
The only thing I like about the Code 3 bars is that they have four rotators instead of two.
Well I have a few of each...Ahem now that the lie is over... Each lightbar has it's own unique and awesome features...
twinsonics have a multidude of mirror and flasher options.
SD bars have night probe, and that wicked crazy thing for california "Select Alert"(wicked used under trademark of cfd125) he's from bahstahn
sd bars have a triple threat
both have 3 different sizes.
sd bars have drive belts which loosen and stretch, twinsonic have chains which do the same...
federal was around about 10yeara longer then SD bars, bought all.
"SD bars have night probe, and that wicked crazy thing for california"
What is the night probe and the crazy thing for california?
It think he means select alert
viewtopic.php?f=22&t=1899
The TwinSonic was available in 1968, the SD somewhere around 1976, so the TwinSonic was the first enclosed lightbar and had a big head start over the SD.
The TwinSonic had the aerodynamics of a brick and by the late 1970's aerodynamics became important as agencies were looking for better fuel mileage, thus, the square bars began to fall from popularity and the more aerodynamic bars like the Aerodynic gained in popularity. Basically, the SD arrived at the end of the square bar's era.
The SD draws more amps than a TwinSonic.
The SD did have a lot of lighting options. The twin rotators on each side with the outboard bulbs 180 degrees apart and the inboard 120 degrees apart gave it a unique flash pattern. SD's could also be equipped with oscillating, steady burn, or flashing lights instead of mirrors and the SD could be had in the very wide triple threat size (two speaker sections, three light sections).
Of course, TwinSonics had their options too. Cascade mirrors, X-mirrors, flasher light over top of a half-height cascade mirror, and the economy series which deleted the cascade mirrors or replaced them with either flashing PAR-36 lamps or a combination of PAR-36's and a V-mirror. Fed Sig did not have anything like PSE's Select-Alert or Night Probe.
Plus you have to remember that before the Twinsonic, everything was beacons... beacons on the Model 11 Twin Beacon Ray or individual beacons like the Model 17, Model 14, Model 184 etc. The Twinsonic was patented and was so unique that it carved a name for itself. The other companies' bars from Code 3, Dietz, Unity etc. were basically seen as wannabes although some of them had unique features too.
I remember NYC EMS using the Code 3 bars with all sealed beams, that's 8 sealed beams per bar, plus a minibar on the rear with another 4 sealed beams and of course all the other flashing lightheads and headlights and electrical draw on the ambulance. When they were idling the beams dimmed and the rotators slowed, you had to punch the gas to make them light up. :lol:
NYC EMS and FDNY also used the independent reflector (non sealed) verion of the mini SD on ambulances and fire units.
shawn1
