My only thought with this, is if you are using a negative horn ring, but the polarity wired, or programming is wrong. A negative trigger horn ring will rest with voltage. If the trigger is set up as a positive voltage, the system will think that the horn is constantly being pressed. Again, I have never used this system, and know nothing about it, but Ive seen similar issues with Whelen cencoms.
