Whelen often forgets that they made some hybrid LED bars with 5mm leds while the Freedom was in the works. I can tell you how to hook it up if I can see the harness. The strobe version wiring is a bit different. The 700 5mm LEDs, unlike the early linear LEDs in the Freedom and Patriot, did not need a special power supply or ballast. They were run off of basic flashers, usually 2 or 4 to a flasher.thanks JohnMarcson i did see that earlier post was hoping to find a wiring diagram w/o having to open the bar up. picked the bar up monday night but won't be able to do anything til i get home this weekend. The factory has been trying to help but all they come up with is the strobe version. At first I was told it wasn't a valid model # I guess alot of their records were lost so that's why I'm reaching out here
Thanks john opened it this a.m. and that's what i have. The forward facing heads are unique as the have the outer leds at a 45 angle the pierce alert has a spot in the gear were it studders but still functions. Thanks again for the helpNever mind, I found the wiring guide. Despite what Whelen says, they made it.
Here is a PDF and some pics from it, looks like each pair had their own ground and power. Regardless, this is the stock configuration for wiring.
View attachment 241053View attachment 241054
