This is a privatley owned vehicle (POV) for a local volunteer fire fighter. The Explorer is a civilian model. Lighting is all new and a mix of Feniex, and Sound Off. Whelen Carbide system with hand held controller.
If I had to guess, he used the ODBII interface on the Carbide, which would be the easiest way for sure.Great Build. Curious do you remember what you did to tap the DRL and make it flash?
OBDII interface cables are read only. They can’t be used to feed signals back to the vehicle.If I had to guess, he used the ODBII interface on the Carbide, which would be the easiest way for sure.
Ooooh that's good to know.OBDII interface cables are read only. They can’t be used to feed signals back to the vehicle.
