12 Volt 5 Amp Power Supply With Mini Light Bar That Draws 6 Amps
Jim1348
May 12, 2017
31
6
Rosemount
Hypothetical question here. With a 12 volt 5 amp power supply, if a mini light bar is plugged in that is rated at 6 amps, what is likely to happen? Will the mini light bar work, but just not be as bright? Will it damage the power supply?
https://www.amazon.com/gp/product/B07K9R65C6/?tag=elightbars-20
I think it is likely to damage the power supply, unless the supply includes over-current protection.
Could be a few things but bottom line, get something bigger. It may not be able to start it. If it does it should have over current protection and shut down. Being a generic supply, it would likely overheat and be a hazard.
In general, a supply with at least 30% more capacity then you need is a good idea.
Reactions: Jim1348
I’ve seen some computer power supplies converted before, even done one myself… 500 watts is a pretty standard baseline on those, and would be a cheap way to run something with overage coverage as Jennifer mentioned above.
Seth
Reactions: Sparky_911
