Whelen Responder LP (Version 1) vs. Whelen Responder LP (Version 2)
Retired1
Jun 1, 2010
1,912
Woodward County, OK
There are two very different versions of the Whelen Responder LP available on the market right now. To help me show the differences, I have labeled them Version 1 and Version 2.
Version 1 uses the 500 Series, 6 tab, LIN6 or CON3 LED modules as found in the Liberty lightbar, Raiders, and linear LED traffic advisors (among others).
Version 2 uses a metal bracket mounted 6 LED light unit.
Whelen Responder LPs are made in metal base and plastic base versions. They are made in permanent mount and magnetic mount. They are available with hard wire or switched cigarette lighter plug power input. LIN6s versions use non-optic domes. CON3 versions use optic domes (example to be added soon). Note: 6 tab, 500 Series, TIR6 and 5mm modules can easily be interchanged into Version 1.
The versions shown here both have linear LEDs and metal bases with hard wire option.
Version 2 overview. Note the inside roof of the dome is smooth - without indentations used to hold the 6 tab LIN6s found in Version 1. The base top is smooth. The LEDs are mounted to the base.
Version 2 with plastic base. Following photo credited to: rwo978
ai174.photobucket.com_albums_w120_350v8s10_WhelenResponderHousingOpenVersion2byrwo978.jpg
Version 1 overview. The base top is ribbed.The LEDs are mounted to the dome.
Version 2 dome.
Version 2 flasher is inset into the base.
Version 2 close up of LED modules mounted.
Version 2 showing the mounting tabs on the LED module and the slots in the dase that the tabs are inserted into.
Version 1 base.
Version 1 flasher mounted on raised plastic posts cast into the dome.
Version 1 close up of LIN6s mounted to plastic posts cast into the dome.
Version 1 showing the retainer used to mount the LIN6s to the dome and the insets cast into the dome to retain the opposite side of the LIN6.
Side by side - Version 1 on the left / Version 2 on the right
Retired1
Jun 1, 2010
1,912
Woodward County, OK
Reserved for plastic base versions
This is the Version 1 plastic base and related components.
Reactions: OliverD
Jman423
Sep 10, 2010
3,391
United States
Thank you, this is good information. I've made this thread a sticky.
If I was going to purchase one of these, I would only get the original R2 (Version 1 in your write-up).
badge22
Aug 14, 2010
934
MI, United States
Is there a way to identify the units that had the defective flasher?
rwo978
5,196
ND, USA
:confused: :confused: :confused: :confused: :confused: HUH?
badge22
Aug 14, 2010
934
MI, United States
rwo978 said:
Whelen knowingly shipped the first release of this mini-bars with defective flashers. First they refused to admit the problem, then decided that the failure rate was acceptable. They continued to ship them until they used all of the original flashers and then started using new ones.
Strobesnmore
May 23, 2010
382
Westerly, RI
Just reading this thread and we sell thousands of these lights yearly and never have had one flasher issue and to be honest they use the exact same flasher. Not sure who started that rumor but they are the exact same light with the same output just went to a different build strictly to save costs. The built time along with the first version was a bit much and even trying to change heads in house was a pain. the newer version shares the Linear 6s with the Justice and cost less to produce. Both versions are very good and I personally like the newer version as less parts and the metal plate acts as a heat sink keeping the LEDs cooler. should you order one both models are backed by Whelen 100%. I know we still have some perm blues and reds in the version 1.
Jman423
Sep 10, 2010
3,391
United States
A Whelen rep made the comment to me that Whelen did this to prevent people from paying $400 for 6 LIN6 modules as opposed to over $600 if they were purchased individually.
That's how I got my LIN6 modules, I found a good deal on an R2 v1 and pulled out the modules. Then I sold the flasher and housing to make the overall cost even cheaper.
As for the v2, I don't have an opinion because I haven't seen them in person yet, but it does look like the footprint of the module is smaller.
badge22
Aug 14, 2010
934
MI, United States
Well, sir, good for you. Eight of my customers, a Whelen rep for over 20 years, and two people at the Whelen tech support office would disagree with you. I know, I was in the middle of it. As for selling "thousands" of these lights "Yearly". I'd have to see that to believe it (did someone put the blue and red version 1's you still have in a hidden closet? :weird: ), but ok. The versions in questions were sold in 2007.
tritan
Dec 6, 2010
32
MI
So is the poly based model of this light the same version 1 to 2. I had the original with red/white in the front and would love to get another.
rwo978
5,196
ND, USA
no, it's the same as pictured above with the mounting tray for the lightheads. The only difference is the aluminum base vs the poly base.
tritan
Dec 6, 2010
32
MI
So I am confused. Other then the changes in flasher unit and design change is there a brightness change? off axis viewing better ?
rwo978
5,196
ND, USA
The performance of the LIN6 and CON3 will be the same, just different mounting platforms. The generaly layout of the modules is identical, they just mount differently. Brigtness and off axis will not change from V1 LIN6/CON3 to V2 LIN6/CON3. However, the LIN and CON modules have vastly different performance. I encourage you to search and read up on this, but from my experience, I would buy the LIN6 version if at all possible.
As to the flasher, they are all identical in all versions, including permanent and magnetic mounts. The only difference is that the magnetic mount has 3 less wires installed on the power harness of the flasher (sync, pattern override, low power). If you were to install these wires in the plug, which I have, you would have the functions available.
Retired1
Jun 1, 2010
1,912
Woodward County, OK
SireLite said:
Did you not get a plastic base version?
I have never obtained a plastic base Version 2.
However, as rwo978 mentioned above, the plastic and the aluminum base lights have identical components. Only the bases are different.
I had forgotten about this thread until recently. I will see what I can do about updating it soon with a photo of the plastic base Version 1 with its individual parts.
rwo978
5,196
ND, USA
ai667.photobucket.com_albums_vv36_rwo978_Projects_20Reviews_Cu3b9c6fbac89a67611c2ce8b01f2594b9.jpg
Here's the poly base. Same aluminum mounting plate.
Reactions: OliverD
