Traffic advisor, arrow, signal master etc info thread
StEaLtH2
Mar 3, 2011
2,159
New England
RoadDawg.. I know on some Whelen controllers it can be changed to control a six or eight lamp array via dip switches.. just a thought on maybe why the ends act a bit shady.
Still doesn't explain all the extra wires tho. Good luck
roaddawg7
Apr 7, 2013
512
Linden, VA
tried the dip switches when I was messing with it. They do not control the anything but the 6 amber leds for the t/a. Oh well ill just part the bar out or try to see what happens when I cut the extra wires out to make it like it came from the factory
dzik
Dec 22, 2016
18
Warsaw, Poland
Hello,
I've got a problem with wiring and programming Whelen Cencom Gold build-in Traffic Advisor.
My TA is 6 lamp halogen integrated into Federal Vista Lightbar.
The first question is: whatever TA type (5 or 6 or 7 or 8 lamps) I setup in cencom gold programming software, the TA controller seem to light up all 8 lamps. The TA pattern displayed on cencom gold keyboard is always 8 lamps even if I program that it is 6 lamps.
Is it normal with concom gold or is it a programming issue?
The second question is: because I have only 6 lamps and controller has 8 outlets, which of the outlets should I leave disconnected?
My first guess was take outlets 1 to 6 and leave 7 and 8. But then I checked that even in 6 lamp program cencom still uses all 8 outputs.
It is important because in some flash patterns (for example Triple To Flash) the farthest left and right lamps blink 3 times and others only 1 time.
And these 3 blinks are on outputs 1 and 8.
So my second guess is I should disconnect some of other outputs, logically 4 & 5.
Am I right?
Is there any manual which describes it in details? I've go Whelen installation & programming manuals but no help in them.
Best regards
tsquale
Oct 12, 2010
10,559
Minnesota, USA
Hello,
Am I right?
Best regards
For your first question: Yes, the TA controller should still illuminate each of the eight lights on the controller still. This is because as you mentioned in your second question, it still uses all 8 outputs
For your second question: Yes, you will end up not using two of the outputs and I believe you are correct that you don't use number 4 and don't use number 5. I'll try to find it in the manual.
dzik
Dec 22, 2016
18
Warsaw, Poland
Thanks for the quick response.
So, what is the purpose of 5, 6, 7, 8 lamp setting, if it still uses all 8 outputs?
And what is the difference between Halogen and LED TA type setting?
