nForce Exterior Light Bar Programming Help
NaiElppis
Dec 18, 2023
5
North Dakota
Hello! I was wondering if there are any programming guru's that could possibly help me change a few settings on my light bar. I have the configuration software and I'm trying to adjust a few things. Mainly, I'm trying to activate all my forward facing lights for take downs instead of the 2 that turn on. I was playing around with it last night and I was able to get the corner lights to activate, but there are 2 lights that would not switch to white, they just stay amber. Also, is there a way to reset the light to the factory settings? When I first plugged in, I saved the original settings but I believe I mistakenly saved over the original file while messing around with everything. I got most everything back to normal, but the front lights aren't turning on when I select the steady burn, only the back lights are turning on for that. If I can factory reset somehow, I can start over and make sure I don't accidentally save over the original file again.
Thanks for any help you guys are able to offer.
ffjwhite
1,082
Bombay, NY
I wouldn't say I am a guru, but I have played with it for a while with my interior bar and in the beginning, it was a PITA. If you want to DM me your file and I can take a look at it and see what's going on. Gonna sound like a dumb question but are we sure they are white modules to the front as well?
Reactions: NaiElppis
NaiElppis
Dec 18, 2023
5
North Dakota
NaiElppis
Dec 18, 2023
5
North Dakota
So I was able to get most everything figured out. My fronts didn't have the cruise function enabled so it was cutting them out when that mode was activated. I still can't figure out why the 2 lights won't go white though. I can turn them red, blue, or amber but not white. I would assume since they have the ability to turn red or blue also I should have white? I'll send you the file in a bit if you wanted to take a look, I appreciate it.
ffjwhite
1,082
Bombay, NY
I think the most they have is 3 colors. I don't believe sound off has quad colors. That might be the issue?
NaiElppis
Dec 18, 2023
5
North Dakota
All the other forward facing lights that are currently activated with the take down option are either red/blue when I activate my overheads in either 2 or 3. Maybe those 2 are red, blue, amber and the rest are red, blue, white? I just think it's odd that they would set it up so you can't have all forward facing lights white.
ffjwhite
1,082
Bombay, NY
Yeah I am guessing that's how that bar was set up. Was this bar a used one you bought?
