New and Used Whelen, Code3, SOS, FedSig, etc..
Oct 20, 2010
809
Rehoboth, MA
All equipment pictures located here: https://flic.kr/s/aHsmd4ZNgo Updated 05/18/2018
All equipment is used unless otherwise stated. Equipment has been tested and in working order and will be tested again prior to shipment.
Prices include shipping costs. If you are purchasing multiple items, make an offer.
For inquiries and purchases, message me for PayPal information.
Red:
-Code 3 Hide-A-Blast x2 $25ea
-Code 3 XT3 $40
-Code 3 XT6 (display use) $50
-Code 3 TRex dash/deck light, single head $40
-Soundoff Ghosts x2 $40ea
-Soundoff LED3 x3 $25ea
-Soundoff Signal UltraLITE Stick, 8 head $250
-Soundoff Signal Predator 2 single deck/grille light (new in box) $45
-Soundoff Signal Predator 2 w/white flange surface mount $35
-Soundoff Signal R4 Series 4" round (new in box) $40
-Soundoff Signal Universal Undercover LED Insert $25
-911EP Traffic Directional Warning Light 24", 8 head $100
-911EP Lightbar module x5 x1 $15ea
-Whelen Vertex x2 $25ea
Red White:
-Star Mini-Phantom $25
-Soundoff Signal Predator 2 dual modules surface mount $70
-Soundoff Signal 4 head undercover LED kit w/flasher and extension cables, 2 red and 2 white HAWs $60
-Whelen Dual Talon, dash model, (no brackets) $40
Red Amber:
-911EP 12" stick, 4 head (x2) $30
Blue:
-911EP Lightbar dual module (most are new) x6 $15ea
-Star Mini-Phantom x2 $25ea
-Strobes N' More 8 head E48 stick, 4 LEDs per module $100
-Strobes N' More Triple Threat, 3 head dash light $75
-Code 3 PAR36 x2 w/clear lens and x2 w/blue lens $100pair
-Code 3 SuperVisor, passenger side, w/2 takedowns $250
-Code 3 TRex grille light x4 $35ea
-Code 3 XT3 $40
-Whelen TIR3 x7 $15ea
-Whelen LIN3 $15
-Whelen 200 Series Extended Fog, TIR6 x4 $25ea
-Whelen Dual Talon, sync model, (no brackets) x4 x2 $40ea
-Whelen Dual Dash Miser, TIR6 (no brackets) $20
-Whelen Dual Avenger, sync model (no brackets) $50
-Whelen Raider 500 Series x2 $60
-Whelen 400 Series w/grille brackets x2 $25ea
-Whelen LinZ6 x4 $25ea
-Federal Signal MicoPulse, flush mount x2 $50ea
-Federal Signal Cuda TriOptic $40
Blue Amber:
-Code 3 Dual XT6 Dash Light $60
Amber:
-Soundoff Signal LED 3 $25
-Code 3 WingMan 8 head $400
-Code 3 Command Stick 8 head (new) $500
-Code 3 SuperVisor, passenger side, 2 takedown, 2 amber, 1 white $250
-Code 3 XT4 $40
-Code 3 XT3 $30
-Code 3 Vibrant 6 LED Hide-A-Blast (new in box) $45ea
-Code 3 MR6 Gen1 (new) $50
-Code 3 LP6100 Rotator Mini-Bar Lens (new in box) x2 $20ea
Red Blue:
-Soundoff Signal Mini-Pinnacle $175
-Soundoff Signal Predator 2 surface mount, split color $35
-Code 3 Supervisor DUO, passenger side, universal mounts (new) $500
-Code 3 WingMan DUO, 6 head (new) $600
-Code 3 Dual Dash Light, w/cig plug $80
-̶W̶h̶e̶l̶e̶n̶ ̶D̶u̶a̶l̶ ̶A̶v̶e̶n̶g̶e̶r̶,̶ ̶s̶y̶n̶c̶ ̶m̶o̶d̶e̶l̶ ̶(̶n̶o̶ ̶b̶r̶a̶c̶k̶e̶t̶s̶)̶ ̶$̶6̶0̶
-̶W̶h̶e̶l̶e̶n̶ ̶T̶I̶R̶6̶ ̶S̶l̶i̶m̶ ̶L̶i̶g̶h̶t̶e̶r̶ ̶x̶2̶ ̶$̶4̶0̶
-Advanced Warning Lights Dual Dash Light (no brackets) (new) w/visor $50
White:
-Soundoff Intersector (no factory flasher) $20ea
-Soundoff LED3 steadyburn spotlight x2 (new in box) $25ea
-Misc Chinese "Rigid Type" Lights (all of them) $50
Siren/Switch Boxes/Misc:
-Federal Signal TouchMaster Unitrol w/harnesses $80
-Federal Signal Rumber (2 speakers and new 2011 Dodge Charger brackets) $250
-Federal Signal PA300 Series w/harness $60
-Whelen HHS2200 Remote Siren with Hand Held Controllers x3 x2 $200.00ea
-Whelen PCDS-9 Serial Control Head $40
-Whelen B-Link MPC01 Multi Purpose Control Head $40
-Whelen 295HFSA6 $175
-Whelen SA316P Speaker $75
-Whelen KKK-A-1822E 8 output Ambulance Strobe Power Supply (refurbished) $40
-Code 3 PA Mics (new) $25ea
-Carson SB-008-25 Switch Box (new) $100
-Soundoff Signal ETSA380 Dual Tone siren and control head $100
-Jotto Window Bars for Dodge Charger rear windows (new) $200
-Troy Products Dodge Charger center console boxes 3x $70ea
David2005b
Mar 21, 2018
3
Vermont
Hello from Southern Vermont--I saw that you have an eight-head Amber Wingman and a six-head Duo Wingman. Questions: are either of these units the Lower Crown Vic Version with the Third Brake Light surround "gap" and/or is either unit an Upper Wingman that mounts to the Crown Vic ceiling? Also, by Duo, I presume you are referring to a double-stack set of modules and the question is whether the height of the mounting metal case is the same as for Standard LED-X modules or is it taller to accommodate the double row? I'll look forward to your reply!
Oct 20, 2010
809
Rehoboth, MA
David, please follow the link in the original post to see pics of the Wingman.
No, it will not fit around the Crown Vic third brake light. It's for the rear lower deck of a Caprice but will also fit the rear deck of a Charger.
It is DUO, as in Dual color.
The front Wingman is a universal fit
