2015 Dodge Charger
Gary599
Nov 29, 2022
19
Florida
Problem 1. Added two small UBL reds for extrra brake lighting, and tied into 3rd brake light. When the brake is applied all the lights come on, then turn off. Disconnected extra brake lights and the 3rd works like it should.
Problem 2. Added two Feniex Quad Q3 to the plate area. I have 3 modes setup and only wired/tested reverse. It does the same thing, lights come on then immediately turn off.
I was told that the lights have to much draw and the circuit is shutting down.
How do I fix this? I'm guessing a relay?
My other issue, is I have Feniex lights mounted on my rear bumper. How do I connect this to my whelen HHS 3200. The built in front and rear wig wags get turned on via my siren panel, but the lights get power from the factory install. The panel is just the trigger. Where as the Feniex lights need 12 volts to power on.
Instinq
