We are proud to announce you the new Wig-Wag Dimmer for Ford PI series.
Designed for vehicles equipped with projector style headlights.
The Wig-Wag DimmerTM controller varies the light intensity
without using the shutters to prevent premature
solenoid failure.
Dims the lights intensity between 40 to 100% to avoid dead
spots in lighting. Ideal for vehicles with the latest headlight
technology such as the new Ford Interceptor and Explorer.
Integrated Functions
Electrical Specs
Operating voltage : 10 to 18Vdc
Operating temperature : -40C to 75C
Current draw : (With a 14Vdc power source)
Standby mode : 0.3mA
Activated, no load : 250mA (max)
Headlight outputs (lamps) : Activated = + 12V ..................................... 10A (each)
Shutter control outputs (solenoids) : Activated = + 12V ..................................... 1A (each)
Wig-Wag input command : Activated = + 12V ..................................... 10mA
DRL output : Activated = + 12V ..................................... 10mA
solenoid failure.
- 2 independent headlight control outputs
- 2 independent shutter control outputs
- 1 Wig-Wag activation input
- 1 Daytime Running Lights (DRL) disabling output
- Flashing speed adjustment via easy accessible pushbutton
- Headlights intensity adjustment via easy accessible pushbutton
- Fast connection connectors for easy wiring
- No external components required
Electrical Specs
