Whelen 295HSF6 Legends
They are held on by sticky backing. Use a small flathead screwdriver or edge of a razor blade and pry the sticker out from one of the edges. You might need to use some sticker remover on the switch afterwards to get rid of the leftover adhesive before putting a new one on.
wolfman
But once you pull the one off, its not good right? We will have to get a new one made somewhere?
You can probably use Scotch clear double-stick tape on the back (they sell it in a standard tape dispenser, yellow in color) or use a little clear glue on it to reuse. I might have some legends lying around... anything you are looking for in particular?
wolfman
Looking for it in this order:
Upper Flash, Lower Flash, Takedown, Left Alley, Right Alley
They didn't have upper and lower flash as legends in the pack. I do have the following legends available though:
TAKEDOWN
ALLEY LIGHTS
L SIDE LIGHT
R SIDE LIGHT
FRONT FLASH
FRONT STROBE
REAR FLASH
REAR DECK
REAR STROBE
Let me know if any of those could help.
wolfman
