twinsonic question
smitty711
Senior Member
May 23, 2010
684
14
49
California
Anyone know if Federal did any with a steday burn light on both sides of the bar and two rear flasher? If so anyone have pictures?
Nope. There would be no where to put the motor. Not that I know much about that particular line at all..
the CTS was the only bar with steady burn and rear flash. Using a Twinsonic 12EF I suppose it would be possible to make one such bar if all you did was rewire it to make the alternating flashers in front- steady.
I think someone was working on a dual CTS, at least in theory here. It requires quite bit of modification to make it work, but it could be a possible conversion, though not factory correct.
How dare you be a slow poke!
But moto is correct if you wanted a feux CTS you could use a 12EF set up and re wire it.
To do a dual CTS set up I expect you would have to move the motor into the speaker section, then custom size the drive chains.
yep, I got one in the works but nothing set in stone yet
