Trying to convince town council to fund equipment upgrades
kadetklapp
Veteran Member
1,568
87
41
Indiana
I serve on three different police departments as a sworn officer. I do this unpaid at one department, part-time at another, and full-time for the remaining one. My unpaid department I help out with equipment aquisition, grant writing, policy adoption, etc. Basically for the last ten years this town had no active LE and is stuck in the dark ages. Two years ago they upgraded their town police car from a 1994 Crown Victoria to a 2003 Impala 9C1 purchased used from a neighboring agency.
It had a full compliment of lighting, only about half of which worked. I've been addressing issues as time permits and I found the siren in this car to be severely lacking. I don't know who the manufacturer is, I don't have it in front of me, only that it has pathetic tones, a cheap PA mic (looks like it belongs on a fisher-price play set), and perhaps the scariest thing of all, is it has ADJUSTABLE volume for not only the PA, but the siren tones as well :lol:
Now, IIRC, for you fire guys out there, the .gov has a set standard at which a siren must operate in order to meet OSHA and traffic safety requirements, correct? Would anyone happen to know if this also applies to law enforcement vehicles? If so, a point in the right direction to look for in terms of the code and regulation would be helpful. What I'm trying to do is present this to the council and give them the ultimatum- either upgrade to an inexpensive, but properly designed siren system (I'm thinking the new Sho-Me is a good cost-effective replacement) or face possible civil liability if the siren is found to be inadequate and an accident or incident occurs.
Not really looking for equipment suggestions, I'm looking for info on requirements set forth by OSHA which establish standards of warning equipment.
You are probably suppose to have at least 100watts & the siren volume should not be adjustable. Requirements & standards probably vary by state. You can probably call or email someone on your states homepage that can point you in the right direction.
That's what I'm thinking as well. I found this-
http://www.ncjrs.gov/pdffiles1/nij/181622.pdf
Looks like the DOJ did a study to see what is best Not sure if this is enforceable, looks more like it's just a recommendation.
There is alot of stuff out there that are recommendations. The trick is to convince the department or govt agency bean counters that meeting these standards will do something for them like make them more qualified for grants or other such benefits.
I'm not going to claim to be an expert on OSHA stuff, but is it possible you're thinking of permissible noise in the workplace for siren volume?
1. There are none established by OSHA, only noise levels for things like sirens that require employers to provide hearing protection.
2. The closest thing to what you want is the SAE standard "J2498: Minimum Performance of the Warning Light System Used on Emergency Vehicles"
http://www.sae.org/servlets/productDeta ... 498_200408
This is virtually equivalent to the NFPA 1901 lighting requirements for "small vehicles" and references to 1901 are easily available on the manufacturers websites.
OSHA wouldn't apply, though that's why sirens aren't bar-mounted anymore. I don't know that ANSI or NIST has ever done anything regarding vehicle sirens. I understand SAE to be voluntary on part of the manufacturer, and doesn't attach to an end user. Your state motor vehicle code may have a section to the effect of "an audible warning device that can be heard at XXX feet." It's probably in the equipment section. Ohio's references "exhaust whistles" as a warning device.
NFPA and KKK all publish specs for fire apparatus and ambulances. There is nothing for police vehicles. I ran into this roadblock while trying to get some additional rear lighting for SUVs, retroreflective striping and/or battenburg blocks for police cars, etc. Our detectives have no emergency equipment in their cars except for a Code 3 teardrop light.
