stupid ss2000 question
911
Forum Guru
May 22, 2010
3,834
5
New York City
i have to re connect the horn in my car, i removed a ss2000 , now my horn wont work...what 2 wires do i need to connect again, i did this like 20 times probaby and i always forget !!!
thanks
It should be one wire underneath your dash that you at one point cut, spliced, and rewired them to either a relay or direct to the smartsiren.
It would also be of great assistance if you posted the make, model, year of said vehicle... ;)
2008 chevy impala, i want to reconnect the 2 wires , that were going into the harness of the ss2000, not under the dash........its easier that way
the white and white w/yellow tracer wires from the 12-pin connector/SS2000 harness are the circuit. Should be able to connect them together for normal horn function, depending on how/if you used an external relay to wire into the horn circuit. Or I think that's what you are asking.
