SoundOff nFORCE 8 Module Traffic Controller
http://www.sirennet.com/soenftcdgs120... The SoundOff nFORCE Family of products now includes a great Traffic Controller. The SoundOff nFORCE Traffic Controller can be configured with any combination of single color 6 or 9 LED, dual color 12 LED or tri-color 18 LED modules. White LED modules can be specified as take-down, work lights or flood lighting. Manual dimming capability for nighttime use and Cruise Mode are included. Use of PC application in conjunction with SoundOff sirens simplifies install with "plug and play" RJ45 capability. This saves configuration time and enhances configurability by directly mapping siren buttons to Traffic Controller functions.
Features:
Modules can be specified in any combination of single color 6 or 9 LED, dual color 12 LED or tri-color 18 LED modules.
Manual dimming capability for nighttime use.
Cruise mode included.
Breakout Box is included.
Save configuration time and enhance configurability by directly mapping siren buttons to Traffic Controller functions.
Designed for interior or exterior usage.
15 feet of cable, enough for almost any installation.
Can be used in rear or front vehicle applications.
Mounting brackets are included.
Specifications:
INPUT VOLTAGE RANGE: 10-16 Vdc
NUMBER OF LEDs AND MAXIMUM CURRENT DRAW at 12.8 Vdc:
6 LED Single Color: less than 1.0 Amp per module
9 LED Single Color: less than 1.5 Amp per module
12 LED Dual Color: less than 1.0 Amp per module
18 LED Tri-Color: less than 1.0 Amp per module
NUMBER OF LEDS AND MAXIMUM WATTAGE @ 12.8 Vdc
6 LED Single Color: less than 6.4 Watt per module
9 LED Single Color: less than 9.6 Watt per module
12 LED Dual Color: less than 6.4 Watt per module
18 LED Tri-Color: less than 6.4 Watt per module
Takedown: 6 LED: less than 12.8 Watt per module
FLASH PATTERNS: 34 Warning and 8 Traffic
OPERATING TEMPERATURE -40° C to +65° C / -40° F to + 149° F.
DIMENSIONS: 8 Module: 35.5" (90 cm) L x 1.9" (4.7 cm) h x 2.47" (6.3 cm) D.
CERTIFICATION: SAE J845 Class 1 certified.
SoundOff 5 Year No Hassle Warranty
Features:
Specifications:
